CAT 27 SAILS
DAVE MARKS
THE TIME HAS COME TO REPLACE BOTH THE MAIN AND RF JIB ON MY CATALINA 27 , 1984 TALL RIG. CAN ANYONE SUGGEST A GOOD SAILMAKER AT A REASONABLE PRICE ? THANKS, DVE MARKS
Phil Herring
Alien
Mar 25, 1997
4,923
- - Bainbridge Island
Couple thoughts
Check the chandlery on this site. Doyles aren't the lowest cost sails you'll find but they are among the best. If you want used, search the forum archives for used sail lofts. There should be a couple good lofts on the Gulf where you are - ask around your marina, too. Good luck! p.
Thos. Kober
Catalina Sails
you might check out this for pre-made catalina sails, they seem alot less expensive than some of the larger lofts.. http://www.sailnet.com/store/departments.cfm?id=398
Drew
Can you sew?
www.sailrite.com sells kits for the C-27 Tall Rig. The material comes pre-cut. You just need to stitch it together yourself. It's not for everyone, but if you're up for the project you can sew your own mainsail for less that $500.00.
