In one design racing there have been many class boats that when 'some' changed to CF spars, the advantages were so vast that those with CF masts became independent and evolved into entirely separate classes, essentially 'killing' the class that they evolved from. The advantages of CF were/are mast 'bendability' for precise main sail shaping ability, significant lessening of weight aloft, etc. However, during that 'evolution' many of the CF masts encountered mast failure due probably in the pursuit to get the 'lightest' spar but risking less strength so if you do go CF you must choose between vulnerability vs. weight aloft. Also, Make sure that your intended 'class' is an 'open class' or 'development class' which accepts changes or if a closed class which keeps the scantlings fixed for a level playing field. Otherwise you may be making yourself obsolete and at great expense.
BTW/FWIW - enhanced mainsail shaping via spar bending usually requires on-the-fly mast raking, so also carefully evaluate your intended class to see if this added cost requirement 'stacks up' with $$$ addition of the CF spar.
There is a middle ground (but check your intended class rules) in that a 'log' type aluminum mast 'can' be tapered, or you can seek an already tapered Al mast, wherin a 'v' is cut from the section through most of the mast top and about 1/3rd the way down on both sides the mast then rewelded ... and a 'moment bending bar' is added to the head - essentially a horizontal 'bar' at the top that extends well aft and the (full adjust) backstay is connected to the aft end of the 'bar'.
Tapering is a 'halfway' and the CF masts through better evolution/knowledge have most entirely replaced the tapered Al masts ..... and those boats that didnt change now sail essentially 'obsolete' class boats. So too, such boats should have extreme 'light weight' and 'precise' laminate sails to 'match' the lightweight spars and matched to the skill of the helmsman. Were talking serious $$$$ here.
Of course this all depends on how serious and how deep your pockets are ... and if such an investment will yield the results you're looking for. However, be sure that you dont become soooooooo much better that your optimization so far exceeds the rest of the fleet that you race with ... that the other boats in the fleet become so less competitive that their interest wanes and the fleet begins to decline ... a common problem in racing and high performance sailing nowadays. When all the boats are fairly evenly matched it then primarily depends on the skill, and the learning curve, of the sailors rather than how much $$$$ you can pour over a boat by buying gimmicks and gizmos.
For serious consideration of a CF mast, I suggest you go to forums such as "SailingAnarchy.com"
Eg.: cfcomposites.com - as an example.
