Can someone explain why Minnesota gasoline does not seem to need filtering, does not phase seperate, and does not gum up? I posted once that I left mixed gas in a tank for at least 11 years and the 55 hp Evinrude ran fine. With at least 13 gasoline engines(some 2-cycle), I do not change filters, change old gas, drain carbs, fix carbs, or put in additives. The Artic Cat started on the second pull after 10 months with fuel in the unmixed tank. Other engines also are left untouched for many months. The Briggs on the leaf mulcher goes at least 11 months. On the Volvo-Penta, I started using non-ethanol gas because of postings and of course, after spouting off here, maintenace will probably be required on most of my engines.
I do highly recommend the Honda 8 electric start.
Bakes
