Capt Tolley, Pt II
Liam:Tolley is a one-part liquid epoxy that has many uses. It goes on white and dries clear. I use it to fill small cracks and seams all over my boat. I also use it as preventive maintenance by running a bead of the stuff around all the screw heads on everything that is screwed thru the deck. I also run a bead along the inside of my toe rail to make sure everything stays dry. Tolley is a great product, IMHO.
