Capt.Tolley's creeping crack cure
Mick Johnson
Were is the ceapest place to by Capt.Tolley's creeping crack cure or any other boat supplies?
Dec 3, 2003
544
None None Rochester, NY
Boat U.S.
Bought a small bottle at Boat U.S. I'm sure the West Marine also carries it.
W
Warren M.
Capt Tolley...
...is really a very good product. All the boat stores sell it. Tends to sell for $10 a bottle, give or take a buck. Buy it at the boat store closest or easiest to get to to.
L
Liam
What is it?
What is this stuff? Is it for gel-coat cracks and crazing?
W
Warren M.
Capt Tolley, Pt II
Liam: Tolley is a one-part liquid epoxy that has many uses. It goes on white and dries clear. I use it to fill small cracks and seams all over my boat. I also use it as preventive maintenance by running a bead of the stuff around all the screw heads on everything that is screwed thru the deck. I also run a bead along the inside of my toe rail to make sure everything stays dry. Tolley is a great product, IMHO.
L
liam
Thanks
Thank you Warren. Good description. I will look for this and give it a try.
