Water ballasted boats, including my Hunter, requires the water vale to be open when laungching.
Then immediate closing the same water ballast valve completely after checking water level in ballast visually. I use a dole rod to prove it is full totally. Never sail with hafl full.
Competely full level and closing the same valve is unquestionably required before hosting sail...... period.
Without the water ballast valve completely closed the water can run back out(loss of ballast) while sailing due to heeling and water seekijng its own level.
Water ballast boats are completely safe if sailed by following mfgs specs and as importantly common sense.
Who would be to try and sail a water ballasted boat witout water...?
