Brad Williams
I'm leaving town in a day for 10 days.....got home too late to call Catalina....and hate to do it on the road without my specs, but here's what I've got.DPO destroyed the maststep on Capri 26. I have a new one and just stasrted looking into replacing it today. In my Owner's book (which is pretty light on specifics) it shows a drawing of a Mast Step Plate Installation (Drawing Number 260-24015).Essentially it shows a 1) Deck Pan, @) a "supplied plate", and then 3) a tabernacle. I'm not sure what this is.....maybe a conversion to allow a maststep -- I don't know how the boat came originally. Well, this supplied plate has two predrilled holes and almost looks like a shim of sorts. It only goes under the aft part of the tabernacle ...ie, just two holes for the two aft bolts.The drawing calls the supplied plate and two 1/4" x 4 1/2 " bolts, and the drawing itself the Kit Bill of Materials. Again, my thinking, it's some retrofit kit.Anyway, I don't have the supplied plate in the twisted remains -- what was it for, anyone have a clue. I do have a piece of plastic block with all four holes drilled. It allows wiring to come up into the mast (radio etc). And because the kit only includes the two aft bolts, I suspect that they are a different length than the original aft bolts. Apparently, the two forward bolts can be reused in the retro fit.Totally confused? Sorry. My problem is that I
