Capri 18 mast
CalebD
Jun 27, 2006
1,479
Tartan 27' 1967 Nyack, NY
Call Catalina?
You might find some, ahem, storm damaged replacement for it on CL or Ebay in the north east.
Nov 19, 2008
2,129
Catalina C-22 MK-II Parrish, FL
You'll probably find out shipping costs more than the mast. Shipping was $100. on my Capri-18 boom, and the boom extrusion was around $60.
Don
Aug 15, 2012
301
Precision 21 Newburyport MA
Check with Catalina first, but if it is Dywer mast they are located near New Haven CT, not that far from NY. You might be able arrange to pick it up to save shipping.
-na -NA Anywhere USA
Call Catalina Yachts in Florida at the plant and ask for Warren Pandy. Tell him Crazy referred you to him as his nickname is Skip or I called him Skippy Peanut Butter.
Catalina has the exclusive rights to the mast section for the 18. The manufacturuing plant in California is now closed. So go direct.
As for Dwyer, you would have to put a new mast step on, new rigging and so forth. Skip at Catalina is a charm to work with. I hope this helps. If not, call Ron Frisosky at 941-914-3890 and he can direct you to the right source. I use to be a small boat catalina dealer for many years and catalina built all their own small masts to inlclude the 18.
crazy dave
Hunter 37 C sloop Punta Gorda FL
Dave, I can't believe Warren is still there. He was very helpful getting us doccuments out of the old Morgan plant in Largo Fl. In the '90's, and he was not kid then.
