Sent you two pics but several comments here
Rob, you should find a vast selection of canvas shops if you sail on the Chesapeake. The issue for you may be where the boat is located vs. where a vendor you end up liking is located, in which case you may need to relocate the boat for a while. So long as you can keep it within commuting distance for you (after work, on a Saturday morning), that's not a bad thing - but you want to work with the vendor as the design unfolds, most especially when s/he's setting up the frame as that will govern the ergonomics of how you end up relating to the cockpit, the companionway and the sidedecks.You will have to accept bending under a dodger bow if you have a meaningful bridgedeck and want to avoid a high profile dodger (which I too would want to avoid) but keep in mind that canvas vendors should be generally familiar with your model boat and also are likely to have photo books that allow you & they to talk about different design approaches while sharing the same visual references.I sent you two pics, one each of our last two dodgers. We learned by using, even tho' we started with a real artist and fellow sailor when building up our first one. I think the advice about removeable panels makes more sense in theory than practice, and you'll see why when you look at the pics...but our first vendor used removeable panels on his own boat, and in hot/sweaty Florida it's easy to understand their appeal in light winds.Finally, grab the Mate and enjoy some dock walking at the local marinas. Take your time, take your camera, and see if you can't find a few boats with similar cockpit/bridgedeck setups that seem to have useable, appealing-looking dodgers. Become your own amateur canvas maker, if only conceptually. If you look for canvas shop labels at the same time, this will also help to ID some of the local vendors you may want to interview for the job.Good luck!Jack
