Well, I got it turn a quarter of a turn with the impact driver and now it won’t move. I can get a pretty good lock on it with the impact driver but I can’t give it full speed. Still, it should give way. This is bizarre. I’ll try the vinegar and more PB blaster, etc but I figured once I got it initially started that it would give way but it hasn’t.
There's a test that was done by a machinist's magazine about the best penetrating oils. I had a difficult to replace carb with a brass or bronze part that for the life of me, I could not get out. I tried the usual wd-40, PB blaster, etc. Every time I gave it another go it damaged the part a little more. So I finally made the concoction they recommended - ATF and Acetone mixed 1:1! I put some into a spray bottle, mixed it up and sprayed it about six times throughout the day. I thought there wasnt a chance in hell it would come out that soon but I gave it a go and out it came! I had been trying to get this thing out for the past two weeks! In less than ten hours it came out with this mixture! I was shocked!
Here's the test results from Machinist Workshop
None ...................... 516 pounds
WD-40 ................... 238 pounds
PB Blaster .............. 214 pounds
Liquid Wrench ...... 127 pounds
Kano Kroil ............. 106 pounds
ATF-Acetone mix....53 pounds
