W
Wally
I can't seem to power my 2GM20F beyond 2000 RPM. If going beyond 2000RPM I belch brown smoke and do not increase speed or RPM. I have done the following:1) Cleaned the air intake foam filter.2) Removed and cleaned the mixing elbow.3) Am in the process of having the injectors serviced.The injectors were serviced a year ago so I find it difficult to believe there is a problem here. The only other things that were done was the Racor fuel filter was changed in the fall. The engine fuel filter was not changed because the Racor was clean. Plastic fuel tank was kept full all winter. Boat is 10 years old.What's next?Thanks in advance for any help or comments.
