G
Grant
Peggy - The Jabsco 37010 electric flush toilet in my Maxum cruiser won't keep water in the bowl. The toilet base is mounted about 4' below the waterline, so the desired water level in the bowl would be just about even with the waterline. There's a 10" or so loop in the discharge line, and I installed a one-way check valve in the intake line per Jabsco's recomendation. The ONLY way I can keep water in the bowl is to give it a good flush, and then immediatly close the seacock on the intake line. My buddy has no problem with his boat using the same toilet!Any ideas? - Thanks!
