I tried to fit my new Fulton outboard bracket on sunday, without the wedge and using some new backing plates inside out outside the transom (ODay 23). Problem is, there is interference with the transom and rub-rail when the mount is in the up position.... So no dice, I have to put the wedge back. Which means I have to fill-in the interior of the wedge, where a couple of pieces of filler came out when I removed it from the transom. I've got a big can of West Fiberglass repair, this should be OK--no? Its the one with chopped glass in a resin and a tube of hardener. Next thing is to try to remove the old mount from the plate that was fitted between the motor mount and wedge. With all the nuts removed that thing seems frozen in place..... That is, unless anyone has any ideas about where to find another wedge-like (in form or function) piece. Interested to hear how it was that some of you were able to ditch the wedge altogether.
