Thank you Guys for your help. The shaft coupling and the transmission came appart after some PB blaster and a chisel. I end up cutting the shaft because the PO had tighten too much the packing nut and it was damaged. So now I have some question:Does anyone knows the shaft length for a Catalina 84 with an M25? Catalinadirect sales 55" and 54" shafts, a manual I found said 57" (for the version with the m18) and the length of the one I cut is 58". I sent an email to Catalina but no response yet. Solid or split shaft coupling? wouldn't be easier to service it in the future with a split one?The cutlass bearing looks good (no play) but since I am now changing the shaft and coupling should I change it too?Thanks
