Candle wax on non-skid
N
Ned Strain
Had some kids (<40 yrs. old) aboard over the weekend and they apparently used candles to illuminate the cockpit area - wax everywhere. What mght I do to remove the wax from the non-skid areas of the cockpit? Ned Strain s/v Family Therapy 1995 h336 Chicago
Dec 2, 1999
15,184
Hint from Heloise!
Ned: This is REALLY a Hint from Heloise! Let us know if it works or NOT. 4. Lift candle wax that dripped onto the carpet? Once wax has hardened, scrape up what you can with a dull knife. Put paper towels or and old, white cloth over the area; with iron on low-warm (no steam), gently press. As wax is lifted, move towels so a clean part covers the remaining wax; repeat until wax is gone. If colored wax leaves a stain, blot with spot remover or carpet cleaner, following label directions.
Paul Akers
Dawn detergent
I've had luck with Dawn dish detergent. Scrape up the excess and then wash with Dawn.
Peggie Hall/Head Mistress
Ice works...
I wouldn't try heat or scraping on the gelcoat. I remove candles that have melted in their holders by putting 'em in the freezer. To remove candle wax on table tops, I put ice in a zip lock and put the bag on the drip. After about 5-10 minutes, I can pop it right off.
N
Ned Strain
What finally worked ...
Thanks to everyone who responded. Getting the actual wax removed was easy - but the oily residue stained the gelcoat and left strange marks on the non-skid. Tried just about everything and ultimately used "Weiman Wax Away - Candle Wax Remover" (appropriately named) by the Herbert Stanley Co. in Gurnee, IL. Still required lots of elbow grease - but it did remove all traces of the candle wax.
