Can you winterize deisel without running engine?
Mar 30, 2011
5
Heritage West Indies 38 Chesapeake Bay
We have just aquired a 1980 Heritage West Indies 38 with a Perkins 4-108. boat is on the hard and due to hull work we cannot run the engine. How can I winterize the raw water side? I do appreciate your help. Rick
Feb 6, 1998
11,723
*Remove impeller
*Re-install cover plate
*Disconnect RW outlet hose where it injects to exhaust elbow
*Place RW outlet hose from exhaust elbow into bucket
*Disconnect hose from seacock and attach a garden hose male adapter
*Use a "Silver King" brass pump to pump AF through the engine and into the other bucket from a seperate 5 GAL bucket.
*Drain aqualift muffler
Note: The Silver King pump has LOTS of power and is the only pump I have really found suitable for this.. This is a life long pump that can be used for many other uses. Very handy and is specifically designed to slide over a 5 GAL bucket and you then stand on the foot brace while you pump...
Mar 30, 2011
5
Maine Sail thank you, I thought along this line but wasn't sure if it was the correct proceedure and I didn't know which pump. Rick
