Got a 340 that I trailer
I've trailered and launched my Hunter 30 T for 5 years, and most recently trailer and launch my Hunter 340.In this region we have no boatyard to launch boats. Hence we all launch our own boats. Included in this are 2 Catalina 34s, 1 Hunter 340, 1 Hunter 336, 2 Catalina 32s, as well as a number of smaller boats. We also have a trailered C&C 40, but he uses a semi tractor to launch his.So if we can do that, a 26 or 28 is no problem at all. The trick is in the trailer. Our spare tire is mounted on the tongue. When launching, the tongue is dropped so the weight is on the spare tire. We then tricycle the trailer into the water using a 20,000 or 30,000# nylon strap. Sounds scary. What is holding your boat up when the marina launches it from a lift. Same strap though wider. Our launch is probably safer as the boat floats off the trailer.So trailer large boats is just a mind set, just as sailing in the ocean. There are tricks, but not complex ones . . . . I'll be happy to post pictures, or explain. Jim
