Can I repurpose this electrical cord?
Jun 2, 2004
3,676
Perfect for the outdoor speakers that you didn't know you needed.
Used to have phone and cable tv connections for the boat
In the age of Bluetooth I haven't bought speaker wire for a while. When I did last year there was a bit of sticker shock.
DaveJ
Apr 2, 2013
528
It is previously stated that #16ga is stamped on the wire, but what else is stamped. There are many different insulations on wires/cables, does it show a voltage rating? If it has a UL designation stamped on it then you can use your friend google to identify what the cable can be used for. Speaker wire for sure, power wire, not sure.
cheers
Oct 31, 2022
119
Catalina Capri 22, Catalina 42 MKII Huntington
Yea as posted in the original post it says “marinco type sjtow-a 3 cond 16 awg phone” on the insulation
DaveJ
Apr 2, 2013
528
Darn, missed that in the original post. This is fine for a power cable, but I would be careful what to use it for. Most 120v breakers are going to be 15amp, exceeding the limit of the #16 wire size. There are good suggestions above for its use, including 2 12vdc circuits with the return wire.
cheers
Likes: Sail22Capri22
JBP-PA
Apr 29, 2022
838
Jeanneau Tonic 23 Erie, PA
well he said ",,,3 cond 16 awg..."
I know! just burn off the insulation and sell the copper for scrap! ;)
Just kidding! Please don't do that.
There are people with stripping machines who reclaim copper.
"One crucial point to note is that most people should avoid stripping the wire at home. Stripping the wire to remove insulation may seem like a cost-saving measure, but it’s a time-consuming and potentially dangerous task. Home stripping can expose you to harmful fumes, sharp tools, and electrical hazards, making it a task best left to professionals.
Instead, the most efficient and secure way to scrap copper wire is to bring it to a full-service scrap metal recycler. These facilities have the expertise and equipment to handle the entire process safely. They can efficiently strip, sort, and weigh your copper wire, ensuring you get the best price for your scrap."
1,534
Are you certain it is 16ga? A quick search finds multiple sources indicating telephone wire is as large as 20 ga and as small as 26 depending on age and application.
As mentioned in post #19, phone wires are normally 24AGW.
I have been in phone business for 40 years and wired many 100 and 200 room hotels and retirement buildings with 4 conductor ( red, green, yellow, black) insulation in a jacket at well over 200 feet pull. I have never seen 3 conductor 16AGW wire used for phone. Even local phone company land lines use 24AGW for very long lengths. That wire is not likely for phone line.
Phone line uses 48vdc when phone is on hook and 90vac at 20 Hz when phone is ringing.
Analog phone uses 2 conductors only.
Your cord has 3 coductors black, white and green with stranded wires are definitely an extension cord for 120vac.
colemj
Jul 13, 2004
1,185
This is a common cord, still sold, and yes it is expressly for analog telephone. It is 3-conductor 16awg - 2 conductors for the signal and one for a common drain and/or auxiliary signal. There will be a RJ11 converter inside the boat for the phone.
I can't imagine anyone needing one of these nowadays, but they are still produced and sold everywhere.
Mark
