There are people with stripping machines who reclaim copper.well he said ",,,3 cond 16 awg..."
I know! just burn off the insulation and sell the copper for scrap!
Just kidding! Please don't do that.
As mentioned in post #19, phone wires are normally 24AGW.Are you certain it is 16ga? A quick search finds multiple sources indicating telephone wire is as large as 20 ga and as small as 26 depending on age and application.
This is a common cord, still sold, and yes it is expressly for analog telephone. It is 3-conductor 16awg - 2 conductors for the signal and one for a common drain and/or auxiliary signal. There will be a RJ11 converter inside the boat for the phone.As mentioned in post #19, phone wires are normally 24AGW.
I have been in phone business for 40 years and wired many 100 and 200 room hotels and retirement buildings with 4 conductor ( red, green, yellow, black) insulation in a jacket at well over 200 feet pull. I have never seen 3 conductor 16AGW wire used for phone. Even local phone company land lines use 24AGW for very long lengths. That wire is not likely for phone line.
Phone line uses 48vdc when phone is on hook and 90vac at 20 Hz when phone is ringing.
Analog phone uses 2 conductors only.
Your cord has 3 coductors black, white and green with stranded wires are definitely an extension cord for 120vac.
