I am trying to find bits of an impeller. Want to put a hose on the intake hose of the heat exchanger and drain at the outlet of the raw water pump. I think pieces are in the oil cooler which I cannot get to.
but you need to count pieces. they may well be in the oil cooler. i would figure out a way to get it off if you can. may have to lift engine up or something like that but if you dont get it all it will bite you back later!
