RF Genoa
The ProFurl is a great system, designed as a furling/reefing system, so, your Good there.Secondly, Any Furling Genoa can be reefed, and although a Seafoam luff pad helps, a reefed genoa does not have the performance or shape as when fully out. This is the trade off of a RF system vs. changing headsails.When the system was changed to the Profurl, it may have changed the max sail luff dimension, if link plates were used, so, the sail may need a recut. And depending on the system models, before and now, you may need to change to a different size luff tape.BUT, before you run off to your trusty sailmaker, you can measure the luff with a tape measure, or more simply, pull out the sail and see if it fits, then if you need modifications, your sailmaker can make them. And it's not a big deal. Good luck.
