can any body tell me what this is???
Joe
Jun 1, 2004
8,323
Looks to me to be a shell of its old self. Can't be a sailboat anymore, for obvious reasons. No outboard... so it isn't a runabout. If it's a rowboat, where are the oarlocks? Hey... there's no tiller or rudder either. So I would call it a hulk... or at best, a barge.
Oct 22, 2008
3,502
- Telstar 28 Buzzards Bay
He don't know much about boats, do he... most rowboats have at least one bench athwartships to sit on when rowing. It looks a bit like a Javelin, but is too small and has less sheer than Uffa Fox's design. :)
the guy selling it thinks its a 12' row boat
May 23, 2004
3,319
I know exactly what it is.....A hole in the water that you throw money into!
Jan 27, 2008
3,092
ODay 35 Beaufort, NC
Buy it
If the owner thinks it is a rowboat offer him 50 bucks for it, then make a mast and boom, get some dacron for a sail. Make a centerboard and a rudder in your workshop, they are easy to make. For about 200 bucks you can have a nice sailboat. Making a mast and boom is easy. I was amazed how easy. Start with three eaqual length boards that are knot free. Mix some epoxy and fibers to make a paste. Should be like peanut butter or mayo. Coat two boards on one side and the other on both sides, alternate the grains in the boards and make a sandwich out of the three boards. Use c-clamps or bar clamps or both and clamp all along the length. Let cure. Hint, use saran wrap under the clamps and pieces of wood to spread the load over a greater area. Now you have a long square piece of really strong wood. How do you make it round? Using a block plane plane each corner to make it eight equal sided. This only takes a few minutes. Sweep up your shavings!! Now plane each corner to make it 16 sided. Amazing it is almost round, sweep up your shavings!! Now plane each corner to make it 32 sided, it is now round. Take a belt from a belt sander and pretend you are shining shoes and sand any remaining sharp corners. You now have a nice long round strong mast. Coat with epoxy, or paint, or varnish or whatever.
Jan 27, 2008
3,092
Oh yeah
To make a centerboard, go to Home Depot or equivalent. They sell laminated hardwood like maple. Cut the shape of the centerboard then use a block plane to shave it into an airfoil shape and to fit the trunk. Then use a belt sander to finish. Coat with epoxy.
Ross
Jun 15, 2004
14,693
Re: Oh yeah
Jibes,
Good plan except that maple wood is only slightly more durable than newspaper.
RAD
Jun 3, 2004
2,330
Catalina 30 Bay Shore, N.Y.
Am I missing something? like a picture? I have know idea what anybody is talking about, is it my computer?
