can a 28.5 be sailed without a backstay
GRACED
May 11, 2010
1
hunter 28.5 perryville
i see alot of hunters with b and d rigs with out a backstay can it be removed from a 1987 28.5 and the boat still be used
Jun 4, 2004
1,087
Mainship Piliot 34 Punta Gorda
Your boat was designed to have backstays. I would not recommend you remove them. Boats without backstays were designed that way.
Dec 1, 1999
2,391
Hunter 28.5 Chesapeake Bay
The H28.5 rig calls for some degree of mast pre-bend, which requires a backstay. I also do not think the shrouds come far enough aft of the mast to support a loaded headsail without a backstay.
Dec 2, 1999
15,184
Warren:
Actually I think I remember that the pre-bend is put into the rig on the bench for the early B&R Rigs. When the mast is stepped the only thing left to do is to get the rig positioned properly fore/aft and port/starboard with the properl rig tension.
Dec 19, 2006
5,836
Hunter 36 Punta Gorda
Early Hunters
The early Hunters with B&R rigs also had backstays and our newer Hunters are setup different with extra cross support to allow for no backstay,you need to sail with your backstay.
Nick
jtm
Jun 14, 2004
314
Hunter 28.5 Dataw Island, SC
Why do you ask? Is there some issue... like the topping lift tangling up on the back stay? Thats been the annoyance for me- finally solved with a boomkicker.
