Bernie
I have the factory supplied Ameriseam campertop on my 260. However, it does not seem to have been installed correctly. I need to use a pair of pliers to pull on the canvas to get the last snap engaged. The aft end of the hatch is not able to be tilted high enough to use its chrome legs to hold it up even if I try to place them at an angle (I have to use some woooden dowels instead}. The top sags considerably between the aluminum inverted "U" pipe frame and the edge of the raised hatch. The rear plastic window is very difficult to zip in because the aft-most starboard snap was installed a couple of inches up the side below the hatch track. Some of the snap screws are rusting. Do other 260 owners with the Ameriseam top have a better fit?
