Ahoy,
Anyone here have experience with Campbell Sailor propellers? I have read a bit about them and it seems their patented prop design has some real pluses. I'm considering one for a re-power.
Thanks,
Bob
Bob, One thing to keep in mind is while almost all sailboats have a prop that will move them forward reasonably well, only a small % have a prop correctly pitched for their boat and drive train.
The vendor of any prop will have convincing evidence of superiority... and their product might work just fine. Their evidence might a bit biased, though. (?)
First, figure out what your correct pitch and diameter needs to be for Your Boat. This sounds easy but it's normal for even the factory-supplied OEM prop to be somewhat poorly spec'd. And then there are later changes made by prior owners and boat yard guestimators.
Our boat spent most of it's life motoring at about 6.5 to 6.7 kts (smooth water and smooth bottom) with various two blade fixed and feathering props. A few years ago I decided to maximize performance under power (and take the hit for speed loss under sail) and go with a three blade fixed. After some optimizing of the pitch and getting all blades equal (they were off a half inch from blade to blade when shipped by Michigan - yikes), our "sailor" three blade prop now drives the boat @ 7.0 to 7.1 kts all day long. That is with the stock 23 hp Universal diesel, with about 2200 hours on it. Revs are the 2400 to 2600 that the factory recommends for this engine, and we can hit about 2900 rpm WOT.
This makes a great difference when covering long distances against the wind driving up the WA coast and of course many a wind-less day in Puget Sound.
So that Campbell Sailor might be just fine IF..... the pitch and diameter is correct for your boat.
But then, your present prop might be a lot better than you suspect if it gets re-tuned by an expert.
After owning our boat over 20 years and using a fixed two blade, a feathering two blade, and now a fixed three blade, I am convinced that prop selection is 90% engineering at the most and the rest is art. The "art" part might even be more than 10%...
Cheers,
Loren
