tracks, winches and cleats
I stayed with the original jam cleats, which makes it easier to bow string the sheet when triming in the 150 by running the sheet across the cockpit. I guess I'm too lazy to look for the winch handle. As for problems with sheet angle between you fairlead on the track and the winch, I had a few too many overrides after I installed track for my 150. I cut a 1' thick wooden plug to sit under the winches, to change the angle the sheet comes into the winch. I have not had an override in all the years since I did that. Too much talking, I finally have a weekend day without soccer, I'm going sailing.Jim Kolstoe, h23 Kara's Boo
