Raw water circulation for my old Yanmar is done by a belt driven small Jabsco pump. Model 2760-0003 to be exact.
I replaced my original pump with a new one 2.5 years ago. Only 150 running hours since. Last week, I noticed the pump leaking. Removing it for inspection, I first checked the bronze (or maybe it is brass) set screw for the pump's cam piece. With hardly any twist at all on it, the set screw simply sheared off. Upon taking off the pump cover plate and removing the impeller, I discovered the set screw had turned pink and brittle. Fortunately the broken segment still inside the cam extracted easily when I drilled through the center with a 1/16" bit. The cam itself is still good yellow metal.
Then I decided to take a look at the cam from my old pump which I had kept around. It is very pink looking. And actually I broke piece off of it with just a light poke at it with a screwdriver.
Is this a common occurance with these pumps?
For now, I have replaced the corroded pink set screw with an SS screw.
Will I be setting up even faster electrolysis due to disimilar metals?
Thanks for any insights.
