Many thanks on the tip about the adhesive. Did not think about that. Makes sense, with adhesives you have to attack from the side. They are tenacious when pulling directly off. Will give it a try.
Another question. My boat has depth transducer mounted alongside the log paddle wheel and raw water intake behind the keel.
We have an original Datamarine depth gauge which I paid $100+ to have repaired a few years ago.
We get depth readings of 2' often when we are motoring or sailing fast which I believe is due to turbulence that is causing air bubbles that is causing bad readings. Of course this sets off the depth alarm which, because its so soft is not really a problem. The Data Marine also does not have a keel adjustment so every time you see a depth the mental arithmetic is required. All I have read about placing transducers points at my location being bad.
So, do you think that O'Day was dumb enough to site the transducer behind the keel or was it a previous owner?
Where is your transducer located? Any suggestions for a good location. I am looking at the Norcross Hawkeye with the thru hull transducer for $107 at Defender. It also has temperature measurement. So I'd like to do it right.
Also, O'Day or the previous owners like 5200 for sealing thru hulls and I don't relish battling to get the present transducer out, just to replace it with a new transducer and finds that I have the same problem.
Any advice is appreciated.
