Hey all, so I noticed last serious rain storm that there was a leak in the roof under the laminate wood trim that covers the mast base from inside. After removing them I saw it was coming from two of the pass thru fittings for electronics going up the mast, not sure which. I hope pass thru fitting is the correct name for this, I added a picture instead of thousand words.
It wouldn't be hard to replace these as there is a disconnect for all of the mast wires inside but maybe there is a better fix? the one closest to the mast already has some sealant on it so this isn't a new thing, though it's new for me after 10 years ownership. Any tips appreciated, maybe even some tip on which one to get if a new is in order.
thanks!
thanks!
