C
Comfortably Numb
In 2001 I asked the question if anyone had mounted a traveler on the pads where the halyard clutches are mounted. The clutches are mounted on the starboard and there is a pad on the port side for additional clutches etc.. The one response I received seemed to be concerned that this configuration would not help make the boat any faster. I really was not concerned with that, but merely wanted to get the mainsheet out of the cockpit. By having it mounted higher it would also help in releasing the main sheet. I will ask Hunter if that would be structurally sufficient on those pads to take the loads imposed by the main. I would appreciate anyone elses input on this topic.
