Hi all
I have a 1984 31 - When the initial survey was done I found with a moisture meter a leak stream that seems to start on the port side cabin grab rail.
I would like to remove it and fill the holes. My plan includes either refinishing or installing new rails with a good bedding compound.
Has anyone removed these rails? I contacted Hunter but they did not have a
record of exactly how the rails were screwed or through bolted to the cabin top.
Also the 5 loop rails I have found on the net seem to be a few inches shorter
than the original rails. Is there a source that I am missing for supplying the correct length?
Thanks and Happy Thanksgiving to all
Mark Nooney
Mark Nooney
