Cabin Table - Hunter 26
  • Thread starter Dan Christensen
  • Start date
Dan Christensen
Does anyone know if the cabin table on a Hunter 26 converts to a berth? There is a slotted fitting under the table and a peg on the mast support. However, there were no instructions with the used 26 when I bought it. Any information would be helpful.
Mark
Lift and rotate
Essentially, you lift the table up a bit and rotate it into position. It is support by the lip at the edge of the V-berth. Use the seat cushion on the table. There should be some velcro straps to hold the cushion in place. Markdb
K
Ken
Yes
Yes it does, if you lift up the table a bit you can swing the large end of the table towards the front of the boat, it then drops down level with the V berth.
