Here's the verbiage from this website:
http://www.suite101.com/content/using-bleach-to-kill-mold-backfires-a115960. Who knew?
Bleach is commonly believed to be an effective fungicide (mold-killer). In one situation, it may be effective: on hard, non-porous surfaces such as a countertop or shower stall. On porous surfaces such as walls, floors, ceilings, and cabinets, however, it is not effective – in fact, it can actually feed the mold and make the problem worse. This is counterintuitive – it goes against the common thought that bleach kills germs. How can bleach feed the mold, when it is supposed to kill it? It has to do with the composition of bleach and the structure of mold.
Chlorine bleach is mostly water. The water in the bleach carries the active chemical ingredient known as chlorine (sodium hypochlorite). Several sources, including bleach-mold-myth, say that the chlorine in bleach remains on the surface of the wood and does not soak down into the wood.
Mold grows in colonies, sending out branches as it grows. Killing one part of the mold will not kill the mold. Instead, the mold comes back. If it has been fed by using bleach or some other household cleaner, it comes back stronger.
How Chlorine Bleach Makes Mold Worse
The chlorine does not soak into the porous materials (wood, wallboard, ceiling tiles), but the water in the bleach does. The bleach might kill the mold that is on the surface of the wood, but because the chlorine cannot penetrate the wood, it will not kill the mold structures that are underneath the surface.
The water soaks down into the porous material to where the roots of the mold are. Moisture is one of the few requirements mold has. Now that even more of the wood has become moist, thanks to the water in the bleach, the mold can spread into that area and continue its feast.
Using bleach on mold is like cutting off some of the leaves of a plant while feeding the roots, and thinking that the plant has been killed. The plant will just grow more leaves, and the plant will be stronger because it has been fed.
The Clorox ® Company, OSHA, and the EPA all have determined that bleach should not be used in mold remediation. Bleach is ineffective and unsafe for cleaning up mold or killing mold. It appears to kill the mold, but just the surface mold is affected – the hidden mold underneath the surface is alive and well – now it’s doing even better. The mold says, “Thanks for the food! See you in a few days!” and the surface mold will soon be back.
When the mold grows back to the surface, often there will often be even more of it. Bleach seems to help, but it makes it worse. There are ways to get rid of this unwanted houseguest, but bleach is not one of them.
