Cabin recessed light wiring diagram
KXL
Jun 8, 2021
4
Beneteau Oceanis 343 New London
We have a 2005 343, and one of the cabin lights is not working. I swapped the fixture with one that works, and that position is still out so I know it is the wiring. I pulled the wires as much as I could and did not find an issue. Any further troubleshooting guidance would be appreciated. Thanks!
Feb 21, 2013
4,638
Hunter 46 Point Richmond, CA
Refer to pages 60+ for electrical circuit diagram in the manual in this link: GENERAL 12V SCHEMATIC continued - Beneteau 343 manual. Troubleshooting your boat's 12-volt lighting circuit is a stepwise process:
1. Replace the bulb...........you already did that
2. Check the circuit breaker switch is on and has not inadvertently tripped
3. Check the circuit fuse is not blown
4. Check the bulb and circuit voltage
You might find these articles on trobleshooting cabin lights helpful: Troubleshooting Your Boat’s 12-Volt DC Lights - Boat Trader Blog AND Why Did My Cabin Lights All Stop Working? - boats.com
Likes: KXL
The "Boats.Com" link above is a great primer for addressing the problem you have.
Loved this statement... "Start with the simple: First look for loose or disconnected wires, and for signs of corrosion at the termimals."
KXL
Jun 8, 2021
4
Thanks for the references!
jviss
Feb 5, 2004
7,090
Tartan 3800 20 Westport, MA
If you note from the original post he's already done all of this. It's a single circuit for all the lights and only one position is out; so, CB is on, circuit fuse - not sure what you mean by this, given circuit breaker - bulb, circuit voltage. All redundant to what he did.
He really just needs to find out where the wires to that lamp position are broken!
