I was not totally happy with our cabin lights on the boat. A friend had suggested that fluorecent lightning was the way to go as it provided the most bang for the buck. I was mostly looking for light than when diffused would allow for comfortable reading anywhere in the cabin. Power consumption within reason was not a factor as we have adequate capacity and carry a generator. Looked at some ceiling mount fixtures but decided against them for looks as well as the need for wiring. Settled on two small table lamps with 13W, 900 lumen, 120V screw base bulbs. Quickly figured that running them through the inverter would consume 1.4 amps/hour per bulb which compares favorably with a halogen bulb. The color temperature of the light is 2700 K or a soft white. We find the light provided is an improvement over the OEM halogen fixtures which by the way remain functional. We had some lamps at home that were not being used and the cost of the bulbs came in at around $3 a piece. WM offers 12V equivalent bulbs for $18 a piece eliminating the need for an inverter. The lamps are very stable and can be easily secured for travelling. Underway our night vison red halogen will continue to light the way. If you do not have power issues and are looking for a low cost upgrade to your cabin lights do consider fluorecent.
