I was trying to replace the old forward cabin lights on my Catalina 27 and accidentally pulled the blue wire out when I was stripping the old wires. I pulled it out about 5 inches from in the fiberglass. Is there any easy way to track the wire? My idea is to use the Dremel to gently cut away at the layers of fiberglass and hopefully find the end of the wire I stupidly removed. I can then use the base of the new lights to cover up the fiberglass "search and rescue". Thank you in advance for assistance.
