Cabin decor
Mark Crociati
Has anyone replaced the material on the sides of their cabin? I just bought a 1976 25', the material has fallen off and a foam padding remains. It looks similar to the headliner material you would find in an automobile. Any suggestions on what I use and how I replace this would be appreciated. Thanks, Mark Crociati mcrociati@aol.com
Mike
Mark, I did this last year...
...and thought of several possibilities. I finally ended up removing the appx. 1" foam on the hull under the old liner. I then purchased a new liner with appx. 1/4" foam backing from Hunter direct. Their prices were less expensive than a couple of other vendors, service was excellent and delivery timely. I dry fit the liner, cutting with a good pair of heavy duty scissors, then glued the liner to the hull with vinyl floor mastic. It looks great and is holding up very well. It is also very easy to keep clean. Email me with any more questions (bartellmike@aol.com). Good luck.
Mark Crociati
Thank you,
Thank you, I've heard different opinions about the Hunter company. I'm glad to hear a positive one. If you don't mind me asking, how much per yard did they ask and what do I ask for. Once again, thank you so much. M.C.
