Cabin Carpet Repair
14
Oday 23 Westport,CT
I have a 1985 Oday 23 and the carpet is coming off the starboard side of the cabin. There is thin layer of yellow foam rubber behind the carpet. I would like to rmove that foam rubber and reglue carpet to hull liner. Any suggestions as to the best way to rmove the foam rubber(scrapping I guess) and what addhesive to use to glue carpet to the fiberglass hull liner... Thanks, Larry
Mar 28, 2005
92
Oday 25 Stony Brook
I did replace
mi hull liner on my O 25 and the foam was a little messy but it came off with a wire brush on a drill. I installed new liner with Dap contact cement from Home Depot. I used the Original formula not the water soluble, it will get a bit smelly and you need to get some air every few minutes but the product works well.
