Blair Dehuff
I have considerable vibration noise coming from deep down in the hull in the aft of the boat on hard exceleration, which increases as rpms increase. It started about two months after the boat was commissioned and has gotten worse over time. It's kind of a high frequency buzzing sound, which is very loud. No vibration noise is present in either neutral or reverse gear. The shaft is aligned properly and nothing is wrapped on the prop and it is undamaged. The cutlass bearing seems to be ok. Catalina thinks it may either be cavitation or some sort of inherent prop problem. They are going to change props on another C350 which has this same problem to see what happens. They are also investigating other possible causes.My prop is a factory supplied 3 blade cruising prop which was sold as an option. What kind of prop do you have on your C350? Does your boat have this problem?Thanks for any feedback.B. DehuffC350 #116
