K
Kilgore
I have a Universal M-18 in my 1984 Catalina 30. The engine has about 1200 hours on it, and I have had the boat for 4 years.The engine starts and sounds great and runs at 700-800 rpms at initial starting idle and will max RPM at ~3200 under no load and 2600-2700 under load.There is no smoke coming from the steady stream of exhuast water. I replace the Racor and Universal filters every 200-300 hours with an oil change. I use the specified oil and oil filter as per the owners manual for the M-18.I replace the zincs yearly. I hose out my stock heat exchanger several times a season. (By removing the end zinc and cover and spraying water through it until it run clean.)I can do ~5.5 knots under power. (Which I believe is normal.) The engine will run between 185 - 200 degrees when hot. It almost never passes 200 degrees, and if it starts to I stop the boat and have always found the cause was something starting to clog my raw water strainer.The bottom line is that everything seems to be running the way it should, HOWEVER when I run the motor in excess of 1 hour (essentially bringing it up to 200 degrees) if I should bring down the idle ABRUPTLY, the 2 alrms on my panel light up and BUZZ. (ALARM and OIL)In this case the RPMS seem to be less than 800 (600-700). If I raise the RPMS to around 800, the problem goes away.I have purchased a new Thermostat, Water Temp Sending Unit, and Oil Pressure Sending Unit but have not installed them yet.Has ANYONE encountered this? I believe that the problem is not really that I am running with low oil pressure, but that the engine IDLE RPMS at ~200 degrees are too low to maintain the ALTERNATOR OUTPUT and OIL PRESSURE required.ANy feedback would be great.Thanks,Bill Bettini"Kilgore"1984 Catalina 30 Hull # 3650
