I get most of my material from talking to sailors. I feel if one mate has a questions others might also. This subject came from a C30 tall rig sailor on the Catalina site. He was complaining about excessive weather helm and how he had to crank on the rudder to keep going straight. The following is my opinion as to how he could solve his problem.
Here's what I said:
It is very difficult to determine the cause of a problem by reading 3 paragraphs but folks on this site and on the SAIL TRIM FORUM seem to do it all the time. If a mate, who understood sail trim, was on your boat he could probably determine the problem very quickly.
Since I don't know how your sail trim was set up let me explain the couple of things that cause weather helm.
The first cause is excessive heeling. The submerged part of the hull creates a force that wants to turn the boat to weather. Additionally, when you exert force on the rudder you're inducing drag and slowing the boat. Reduce heel and you reduce weather helm.
The second cause is mast RAKE (not to be confused with mast bend). The boat thinks you picked up the mast and moved it aft.
Why does this happen? In very simple, non scientific terms here's what the boat is reacting to. There are scientific names for the following stuff but let's keep it simple. The boat has a exact center point -- like a pivit point. Additionally, the mainsail has a exact center point and this is important especially with a mainsail the size you have on a tall rig. Both the center point of the boat and the mainsail have to be vertically in line. If the center point (DRAFT POSITION) of the main is aft of the center point of the boat, you get weather helm. Move the draft position forward and you reduce weather helm.
Sail trim is very simple to deal with once you understand DRAFT DEPTH, DRAFT POSITION, TWIST and ANGLE OF ATTACK. If a mate does not underatand those four elements, sail trim will never make any sense.
