Terry Parker
I have friends who sail a 1993 C 30 (likely my next boat). Whenever it has rained, they find water gathered under the engine. THey think it's coming in from the cockpit somewhere. The water collects below the engine because there is a cross member between that area and the bilge, so the water has to be manually pumpoed out of there.Several questions:1. Is there supposed to be a channel connecting that area with the bilge?2. Could a drain hole/channel be worked into that area?3. What is the most likely source of the water's entry?Thanks!
