C30 original galley stove
H
Henry Zimmer
Can anyone tell me what the original galley stove was installed in the catalina 30? I have a 1988 C30 and the stove had been replaced with a shore power fridge. I'd like to reinstall a propane range and I'm looking at purchasing a gimballed Seaward Princess 2 burner range and make use of existing original LPG system. The Seaward princess measurements are; Overall size(WxDxH): 21 3/8 x 17 x 22 1/16" Cut out size(WxDxH): 21 3/8 x 21 x 22 1/16" I'd like to be certain this model will fit in the original range location without modification (if possible). Thanks Henry
David Moon
Seaward Stove
I have a 1990 C30 and the standard stove is the Seaward Princess model 2122 gimballed two burner stove with oven. Same measurements you give. Looks like you are getting the same stove it came with.
