C30 hurth transmission levels with 5411
21
- - San Diego, CA
I have 1982 c30 with 11 hp 5411. the hurth transmission has a fluid dipstick that appears to have two marks on it. there is a definite mark near the bottom and a puzzeling mark near the middle of the stick. i found in the archives that the bottom mark is the level to use. i am looking for confirmation that the bottom mark is the one i should be using.....the manual isn't specific enough. thanks in advance.
Yes, use the bottom mark
It always amazes people when they think: "Wow, that's hardly any fluid at all." It isn't much, but that's the mark. ALSO, very important: check the level with the stick just resting on top of the housing -- do not screw the stick in to check the level.
Oct 7, 2006
21
- - San Diego, CA
thanks
thanks stu. although this might not be the place to admit it, i'm afraid i've been running my transmission over filled. i will correct. t
Tom, what manual are you referring to?
The engine manual says little about it, and is written and published by a completely different company than the transmission vendor.
Jul 1, 2004
398
Catalina 30 Atlanta GA
Do you check it cold!!
Great info. and thank you. One question though..........Do you check the fluid level with the engine turned off and cold? Or like an automotive transmission with the engine running and warmed up? Could it be the higher mark on the stick is for expansion of the fluid when warm or hot? Bob Universal M-18
Oct 7, 2006
21
- - San Diego, CA
cold
bob....if it is any good info...i checked mine cold....i got the fluid level down to the bottom mark and did it when the trnasmission was cold t
