David Garrison
Hi. I am considering installing a new bilge pump on my 1986 Catalina 30. Right now, I am looking at one of the Rule pumps - either the 1500GPH or the 2000GPH. Looking for what other folks are using and if you know anything about these two pumps or have opinions on other pumps.Additionally, there seems to be just as many bilge pump switches as there are bilge pumps! Some are built-in, other are floats with mercury, floats withhout mercury, air pressure and current sensing. I looked at a switch called the "Bilge Buddy" which has two metal prongs that sit in the bilge. When the water reaches the prongs, an electrical circuit is completed, the switch closes and the bilbge pump is turned on. Has anyone used this (or this type) of switch? Any recommendations on other switches to consider?Thanks for your help!David GarrisonSeattle, WAs/v Kindred spirit
