C27 rudder
1
Catalina 27 Kootenay Lake
e modified the original rudder on our 1979 C27 and it now sails great, but the rudder is really hard to handle under power. We have an inboard engine and folding prop. How far should prop be from prop. It seems it is the prop wash that makes the steering so hard. Ideas would be appreciated. Thanks
Did you have that problem before you made the change to the rudder? If it's the same, then it is simply prop wash from the prop on the rudder and ALL inboard boats require that the wheel be turned slightly to the right to keep going straight. The C27 Association website 'board may be able to help in more detail about dimensions and clearances. www.catalina27.org
Oct 13, 2008
14
catalina 27T jamesport
I have the same problem with my '74 c27T, when I get to about 3/4 throttle. It has the original rudder. I just back off on the throttle. The difference in speed is very small, but much much easier to steer.
