G
George
I am in the process of acquiring a '76 C27 tall rig, and in looking it over it appears that most of the retrofits have yet to be done. I think I am looking at replacing the through hull(s) since I saw what appeared to be a fiberglass volcano where the drain for the icebox goes through the hull, the spreader sockets, etc.. In looking at the issue of the eye bolt/u bolt retrofit kit(s) for the shrouds issue, I'm not sure if I need to do the retrofit or not. The current fitting has a somewhat rectangular vertical fitting that the shroud attaches to above the deck, with one bolt that comes through the deck and passes through a 3" x 6" metal plate on the ceiling in the cabin before it is fastened with a nut. Is this the "eyebolt retrofit kit" that I have heard about as the precursor to the current "U bolt retrofit kit", or is this the original way the boat was built, and exactly what I need to replace??Thanks!George
