G
Gordon S.
My newly acquired '88 C27 shows a full tank of diesel on the gage continously. After 10 hours of motoring on the delivery trip. the gage still showed full. It is a 15 gallon tank supposedly.I have checked the sending unit with an ohm meter and it shows about 30 ohms with the tank about 90% full and I can see the resistance changing as the boat rocks at the mooring. So it appears good.At the gage end, when I short the gage it reads full. If I put a resistor box across the input I can make the gage register in steps down to empty as I add resistance. At 10000 ohms the gage reads near empty. The shape of the tank indicates that most of the fuel is in the top 1/2 so naturally the gage would be slow to show fuel usage from when the tank is full.I do not want to pull the sender in mid season as it looks like you can get into big trouble here and somehow one of the hold down nuts is already missing.Any ideas? Could the gage be faulty even though it seems to be working?Gordon S. C27 6529
