Thanks for the info
Thanks for the info
You'll want to make sure the transom is capable of taking the weight AND the torque. Your hull is probably plenty heavy enough but a backing plate wouldn't be a bad idea to stiffen and help spread the load. My choice would be a piece of decent 3/4" plywood, kerfed so it will conform to the shape of the hull then epoxied (slow hardened and thickened filling the kerfs) into place for a backing for the OB mount. Then drill out (mount) mounting bolt holes, fill with thickened epoxy, and drill again to seal the plywood and avoid water damage.
Extra long shaft motor would be my first choice, can be mounted high enough the reach from the cockpit (and keep from being "pooped" by a following sea) without acrobatics while keeping the lower unit in the water. There are also very cool systems available (Power Tiller) that allow remote throttle and shift control from the boat's tiller.
My Tohatsu 6hp 4 stroke pushes my 5,000lb, 24'11" boat around very well with no currents or tides to worry about. I started with the 8" pitch prop which did not work well in slow maneuvering and so went to a 6" pitch (high thrust) which is great for slow stuff. The draw back is now I have to run higher rpms (louder and more fuel consumption but still only about 2/3 gallon/hour).
I plan on using the 8" pitch for longer trips where I would motor longer distances.
Mine is an older model (2004 or 5) with the side shift, much rather have the front shift and the alternator kit like on the newer model Sailpro that Rob described.[/quote]
