Stop the Slap
Ted: I wouldn't put a PVC pipe inside my mast because of the weight, but you have to do something so that the wires don't bang around inside the mast, when the boat rocks from side to side. If you ever plan on sleeping in your boat, or you think anyone else in your marina might want to sleep in their boat, you must address the problem of the wires banging the inside of the mast. What I did was make "X"s out of plastic, like a soda bottle or milk jug. They had a hole in the middle where the wires went. I then used wire ties to hold the wires on them every few feet. I then pulled the assembly into the mast. On a C-22, there is an aluminum spacer between the spreaders. This makes it a little tricker. If I remember correctly, I pulled the assembly with the plastic "X"s down from the top of the mast, then pushed some of the "X"s up from the bottom with a pipe. This is a very light weight solution to the wire slapping problem. If you have any questions, just reply, and I'll send you some sketches or photos to better explain what I am talking about. Aldo
